Vroom.
I am not sure but based on my research I don’t think that would be a good idea. A 7.5” minimum requirement is pretty far away from a 5.5” steelie. I would try to find a wider aftermarket steelie you like that fits your needs. Would imagine it would be more likely for the bead to break its seal if you were off-roading or took an aggressive turn on the highway or something. Just my two uneducated cents. Maybe some 15 x 8s?Is it safe enough to run a 33x10.50x15 on a stock 15” steelie? (5, or 5.5” wide?)
Bfg AT KO2 size chart wants a 7.5” wide wheel. Do we care?
I’m following this thread with great interest. Stock wheels, but could go wider if recommended. Looking at 33” tires and am adding the DC rear quarters this Spring. 1.5”SL, 1” BL.
Josh
That's the drivetrain that's in my Bronco, and I wouldn't change it. Also, mine still has the 28 spline axles which really should be considered "maxed out" with 33" tires.Thanks for the input. The setup I am running will clear 35's, check out "the duck" bronco which runs 35's. I plan to run a 5 speed NV 3550 with 4:11 gears.
What size tires do you have? I am assuming something close to 33s? What kinda power are you putting out and how does it behave in 5th gear at 65mph? Thanks!That's the drivetrain that's in my Bronco, and I wouldn't change it. Also, mine still has the 28 spline axles which really should be considered "maxed out" with 33" tires.
Me too. I remember seeing a new 79'-80' Toyota pickup with 31-10.5-15's and thought that was the shit right there!haa I remember when 33 s were massive tires
Yes, that's the year. In 1980 I bought a new Chevy Luv 4wd, put a 3" body lift on it and still couldn't even fit 31's.Not to go off topic, but sorta like this?
On 33 x 12.50s, dang I still miss this rig......
I was so envious of the Toyota's rolling so effortlessly down the beach.
Wish method would do that size/bolt pattern in bronze……I just upgraded from 33's on 15 inch wheels to 35's on 17x9 Method Wheels. Love the new setup.
I got a 79 LUV 4x4 after seing it at the LA auto show. Lifted it with torsion bars in front and added leafs in back. Ran 31x10x15 and special odered some Mickey Thompson gas shocks.Yes, that's the year. In 1980 I bought a new Chevy Luv 4wd, put a 3" body lift on it and still couldn't even fit 31's.
