YNOTBOB2007
- Oct 2, 2007
- 207
Hello....my bronco is wandering more then it used to and I have a question about the track bar bushings. I can see about 1/8" side to side movement at the passenger side bushing when a helper turns the steering wheel. One mechanic said the bushings were loose. The castle-nuts have wires through the stud to prevent loosening, but should I remove the wire and tighten them to see if that works? If so, what torque should I tighten to? Maybe I should replace the bushings too or try tightening first? Thanks!
