I inherited this Bronco. I’m not that familiar with driving older vehicles on the highway so I don’t have the greatest baseline for how it should feel so I hope I can explain my issue on here good enough that y’all can point me in the right direction. I’ve soaked up a lot of knowledge from different threads here. I think I have gathered enough info on my truck but we will see.
67 with v6 and 4speed manual. Idk what transfer case or axle gears ratios. Tires are 31/10.50 28psi. I think it has a 3.5 inch suspension lift. I’m pretty sure that all the bushings and ball joints are in good shape. Steering wheel has around a half inch of play.
I measured the front tires with a measuring tape from a consistent point and got the following measurements.
Top 58(as close as I could get)
Bottom 57 5/16 (as close as I could get)
Front 57 11/16
Back 57 11/16
had it put on an alignment machine also.
what front end do I have? what degree c bushings I have? And or please explain how to tell.
For the driving problem when turning around curves I have to recorrect all the adjustments I make. I’m not sure what to call it idk if this what is referred to as wandering or if the truck isn’t returning to center. It seems like the latter is a more accurate description but I’ve have seen many of these post talk about it like this. Maybe what I’m doing is “bump steering” but I’m not sure what that really means either.
It’s seems to be worse if I’m coasting. If I’m braking or accelerating it doesn’t seem to be as exaggerated. And at speeds between 25-55 ish
From what I’ve gather my canter is less that ideal and my camber is too positive and that’s kind where I’m at.
I’m hoping to get a good idea of what if anything I need so I can order everything at once but if it becomes a process so be it.
Front 57 11/16
Back 57 11/16
