I been fighting some steer wandering, all new bushing front and rear, 2.5 WH lift
Was it doing this before the lift at all? Did you change or add any other items? Steering linkage for example? What about tires and wheels? Brakes?
caster and camber correct
What is correct? What are the exact settings?
What degree?
Did they give you any trouble with setting them up? Too loose, or even too tight?
No bump steer. just a bit of "this wat and then that way"
New Bluetop steering box too and with tight steering column. but I'm finding with the stock non-adjustable track bar, so the front end is 1.125" to the right (of center). Since the front end is not in line with the rear, could this be "destabilizing" the steering quality?
When it was installed did you verify that the steering box was centered? Is your steering wheel offset to one side? It should be, with a 2.5" lift and no corrective measures.
The box could very well be off-center which will potentially contribute to wandering.
Do you mean to the left? Driver's side, correct?
The axle swings left when the truck is lifted.
Definitely. But not much without other things putting their input in I would not think.
As others have said, air pressure, tire type, tire age, tire size, wheel size, wheel offset, trackbar ANGLE even more than length, looseness in the rear.
Those in addition to a steering box being off-center and ball joints being too loose or too tight.
What type of steering linkage are you running? Stock or aftermarket?
What is your actual toe-in setting, as well as actual tire diameter. Reason being is that factory toe-in specifications are not always correct for larger than stock tires. And toe can make a HUGE difference.
Enough of a difference in fact that you should be experimenting with toe-in variations just to see if your current setting is correct for your setup.
And definitely do the test with a helper turning the wheel back and forth while you watch things around the vehicle. Especially the upper and lower trackbar mounting points. You're looking for ANY SLIGHT movement of the bar, the bolts, the brackets and anything else. Even the tiniest movement of the trackbar will allow wandering on the road and an off-center steering box will just make it worse.
