My second Bronco... Crawler build...
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
At home- it definitely won't fit into the garage... Had to remove the top and passenger door.
The drip rail on the top is good, but both sides and lift gate are shot. Anyone need the glass??
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Pulled the top and risked pushing the windshield down... But was happy with what I saw... Dirt and mud, but no rust or rot.
Awesome look, no cage, no top, windshield down!
JohnJohn
Richmond
Re: My second Bronco... Crawler build- pic heavy!
Sweet!
If you want a hardtop lift gate I have one with glass you can have. I trashed a top but pulled the lift gate off and have no use for it.
Just let me know and good luck with the beater.
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Sweet!
Thanks John, but I am not going to keep the hardtop. I may try the safari top look, but no full hardtop.
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
On to the spare parts provided with the truck...
AFR 165 heads with ARP rocker studs and Isky adjustable guide plates. Included Scorpion 1.6 roller rockers. Came off POs dad's F100 when he did a 460 swap.
E303 cam... Already sold to a Mustang buddy for $150...;D
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Very dirty Cobra valve covers
Misc aluminum radiator, electric fan and hoses... No leaks with pressure.
Extra hood- very good shape, cuz the one on the truck is no good
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
I will take some pics of the good and bad tomorrow... It was a really LONG day! We did get it o fit in the garage, I have some stocker roller 8 lug wheels to throw on it and a lot of work.
Last pics for tonight... Pulling into the garage in my ghetto lean seat... I still had to duck under the garage door!
tasker
all knowing of nothing
NH
awesome! all coming together now.....less than a week, you better get cracking!
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Thanks for the vote of confidence, but I would drive this down my street, much less around nice high dollar EBs! Next year my friend... Patience!
BTW- I need you to hook me up with those floors we talked about... Also- any spare marker lights or tail lights? Apparently he PO didn't like lights... ;D
tasker
NH
i am sure, gimmie a lsit of what ya need
HOJO
Cedar Bluff, VA
TD,
I have a ton a spare bronco parts, boxes and boxes, including lights and markers and covers you need to come over and look thru what I have
Lee
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
TD,
Lee
Where you been man? I am off all 4th of July week... Let me know your schedule and I will come take a look!
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Started doing a little work today. Pulled the tires to throw on some rollers... Each tire had 2 or 3 actual lug nuts and the rest were standard (non-acorn) nuts.
Got to messing with the floors... The actually felt somewhat solid, but were obviously sagging and fiberglass end over. 1/4" thick Fiberglass, but the extent of the damage was readily visible from underneath.
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Digging into the suspension components... Can anyone tell me what's wrong in these pics... Besides the shock being at max extension, the poor steering and trac bar?
SC74
Good base to start with.... the demo is fun!
I'm subscribed ... I know you will do it right. Keep the pics rolling ;D
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Thanks Robert... its funny to see a truck with good components so screwed up...
Above the D60 is actually rotated forward... and the shackles on the rear leafs don't even work!! Anything to get a truck tall enough for 39s!!
I have to see if I can remove the body lift or if I need it for the 351/C6/205
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Do you consider it progress if you are still tearing it down...
Pulled the super awesome dual front shocks! I also got the front fenders & grille off. Looking for rot... Found some in the rockers, which will be cut off anyway.
It looks like it may have had a driver side fender bender at some point. Also- without the pass side front body mount, the rear of the inner fender has torn and is weak...
SC74
OH yea... demo is still progress!!! Got to tear it apart to build it back :cool:
Overall it looks like it's solid - I've seen a lot worse! For what you are going to do with it I think you've picked a good one.
