clinem03
- Sep 9, 2017
- 400
I continue to get a lot of oil (?) leakage from under the front of the bell housing between the plate and BH (see photos). It has been a constant leak since the rebuild. I had the clutch and fly wheel replaced a few hundred miles ago, and the leak has been persistent before and after the rebuild of the transmission. We didn't replace the rear seal when the transmission was out b/c it was bone dry. I should also note that the fluid leaking out is always jet black, even when my oil is clean/changed. It tends to flow much heavier when the engine warms up on longer drives.
Could it be anything other than a rear seal leak?
