ox1 How much noise does yours make. I've very disappointed at how much sound comes out of mine.
This is one of the issues with Broncos in general I feel. The main reason I recommend insulating things like the heater plenum/box and wiper motor cover. Just so you don't have to listen to all the racket.
Not sure how to make it sound like a modern car, but at least it should be better.
He said run a hot wire to a toggle. From your Battery & Straight to the Blower Motor. Bypass the Resister. It'll put straight 12v to the motor.
Heck it was like adding OVERDRIVE TO THE MOTOR.
Well, that "can" work. As it obviously did in your rig. What kind of vehicle was that by the way? Bronco, or something else?
With ours, HIGH does bypass the resistor. Only LOW uses it, and the wire for HIGH goes right around and connects directly to the wiring running to the motor.
That's not to say you can't benefit of course. I have suggested making relay kits for horns and heaters, just like you do the headlights. The three-H's of Bronco relay wiring.
With new wiring and switches and fuses, you really should not have any voltage loss anyway. But in the real world that probably is not quite true and even half a volt can make a difference.
And the older the wires and components get, the worse it gets.
If dealing with older stuff then, it would not hurt to first check voltages, then run new, and hopefully larger gauge and/or shorter wiring if needed.
