KennyB
Going with 4 Link. Question is: Coils n Shocks? Or CoilOvers?1972 Bronco Ranger, 3.5” Front Coils, Bent n Twisted Radius Arm Extensions. 2” Body Lift. Front Hoops. Body off rebuild. 1989 AOD Tranny. I have a NEW GT40 302, Dyno’d at 302… Ready to add 12 volts and a Gas line to. (It is For Sale) Then, I bought a Weiand 174 Blower. Now, we’re building another 302 to handle the Blower. Going to be a daily driver with Power Steering and A/C. Going with Explorer or 5.0 Serpentine setup, (the Explorer Harmonic Balancer isn’t the BEST choise for High HP ) and cutting down the Blower Snout to work in the Serpentine system. HP Guessed at 550 with the new Motor.
Oh, rebuilt 9” with Posi, and 4.56:1 gears, and 4 wheel disk. (76-77 Dana 44 Front as well) Running 35” Tires on 17x9 Rims, with 1.25” wheel spacers.
So, Instead of dealing with traction control on Leaf Springs, I spent all weekend Reading up (it’s Raining) on 4-Link Rear. I like the kit from Synergy http://www.polyperformance.com/shop...rd-Bronco-Weld-On-4-Link-Rear-Kit-p-2394.html and the kit from Duff http://www.jamesduff.com/eb/suspension_systems.html I’ve read about NOT Welding the housing on the 9” but, I really like the Duff Truss. Duff’s spring kit says it’s a 5.5” lift, then I found Balistic Adjustable Upper spring mounts http://www.ballisticfabrication.com/Adjustable-coil-buckets_p_1183.html. My Mechanic had Bad experience with Heim Joints getting noisy, and I like the “Serviceability” of the Johnny Joints. With all the parts I like it’s looking like I should piece together a kit with what I like.
My Exact questions are down to: if I go Coils and Shocks in the Rear, (to match the look of the Front Suspension) and I only want 3.5” lift, what are some good Coils to use? (The Rear weighs A LOT less than the front) Or, If I go with CoilOvers, (I like the Price and performance write-ups on FOA http://f-o-a.com/shop/index.php?main_page=product_info&cPath=25_30&products_id=5 CoilOvers) what is the weight at the Rear Axles? I want the Bronco to Sit Level.
