Fix or replace body?
JB Fab
I don't think your body guy understands how much time he will put into a "new body", take it from someone that bought one of the supposedly better ones....
fvb100
fvb100
My research led to the same conclusion. But I think he will agree. For some (or most) of us this is all new territory I guess.
fvb100
fvb100
Agree the new bodies still need allot of work! How are your door pillars?
They seem good. I think the former owner said the body had been sitting in a barn like this (before blasting) since the mid 90's. All rusted parts are from before that.
OX1
Well that sucks, as that was my plan, "someday"..............
bmc69
That's in far better starting condition than all but maybe one of the 12 EB's I've owned or still own...
unimogger
Philthadelphia
As you are paying someone to fix yours, a new tub may certainly be cheaper in the long run. Especially if you sold that one. If you were able to DIY the repairs, then by all means it would be cost effective to save it.
If I was making my "shop rate" for the time I've spent on my tub, I could have bought a new tub, or a nicer bronco.. For me it's easy to justify a few hours every evening, but I can't justify the 14K for a new one.
hunter1
Maryville, Tn
Tub
Your tub is in a lot better shape than the one I started with. I ended up using stock tail light post and support, cowl panel, windshield support and windshield frame. A small section of the upper trans tunnel was also salvaged. I will be able to use the hood and radiator core support as well after some minor repairs. every other piece will be brand new. The one I bought would have been a waste of time to try to salvage but it did have good running gear and a good dash panel.
tabyers
Indiana
Absolute keeper. Put another person on your list of potential buyers if you are tossing this. The only reason I’m going with a full replacement is door posts. If your upper rear quarters and your door posts are good, there is no reason to look elsewhere.
fvb100
fvb100
Just had a good talk with my builder and we will fix this tub. Probably replace the whole front floor pan area. Will let you know how it goes.
fvb100
fvb100
This is a fairly classic "build vs buy" scenario. Except in your case, it sounds more like a "buy vs buy."
If you are paying a "builder" to do your metal work, then you are looking at $75-$100 shop rate. I just replaced the floors on my 70 Bronco. I estimate that I have 5 days in the floor (cut out the old, dress the spot welds, fit the new, drill holes, plug weld, grind, dress the backside, seam seal, prep, and prime.) So if I were paying a shop...that's $4K. If I paid a shop that charged me $20 per hour for a laborer to do "grunt work" and $100 per hour for skilled work...then you are talking about $2K for the floors.
The only way that restoration can be cost effective is if you have access to cheap labor. Most of the projects I work on earn me about 10 cents per hour...
I'm sending you a PM.
5 days and how many hours is that?
fvb100
fvb100
We started work on the body.
taipeichris
Congrats!
Keep it, there's something really nice about original sheet metal. FYI, make sure you investigate the channel in the cowl. Mine rotted out, the only place on the entire body and I found a "how to" article on replacing it with a 2x4 metal tube with out replacing anything else.
Good luck and post progress photos!
:cool:
fvb100
fvb100
Congrats!
:cool:
Great! Thanks for sharing your experience.
fvb100
fvb100
Congrats!
:cool:
Where did you find the article?
