Duffy's 77 Build Thread- Restomod, daily, re-uncut
D
duffymahoney
Trying to match my PPG argent on my grill is a pain. The goal is a powder I can use on my build. This seems as close as I can get with prismatic powders. Accurate silver.
bigmuddy
Marthasville Missouri
Looks good, I don't know think anyone would notice unless you were maybe parked next to a painted argent colored grille. Then only risk your price and ridicule among the bronco elite;)
JefeAZ
Tucson
Oh yeah thats close enough for sure. Ive been there before with powder swatches haha. I think I had 18 samples mailed to me before finding what I wanted on the Raptor bumpers. You can also have it clearcoated afterwards and that can change the shade of grey
D
duffymahoney
Hydroboost day! Sleep is overrated.
I have never liked my pedal feel with my vacuum booster. I hope this fixes it. My plan is to not use the wilwood bias adjuster.
D
duffymahoney
One of my glove boxes is back from powder coating. This is the epoxy primer powder. Pretty neat tech. My bronco isn’t a ranger, but I always loved this badge.
JefeAZ
Tucson
The brake pedal in the Bronco is firmer than the Raptor haha. You wont believe how much of an improvement it is
D
duffymahoney
Well these turned out awesome. High end stainless (i think 316) and milled to perfection. Next is cut up a tire carrier and weld them on. Plus the machined brass bushing inserts. No more bent and rushing pins!
D
duffymahoney
Well somebody decided it was a good idea to fill these glove box hinge holes (me years ago) can anyone take some detailed measurements for me? I need to drill it from the bottom.
D
duffymahoney
Pins started out as 1.5” stainless round bar. Either 304 or 316 (machinist thought it cut like 316) At the pin size of 5/8 it has a tensile strength higher then grade 8 bolts. It was in my brewery bone yard. I’m guessing for positive displacement pump shaft.
At the machined 5/8 it should have a tensile strength of around 80k psi.
D
duffymahoney
This came out so nice.
D
duffymahoney
2nd glove box is prepped. I’m loving this powder epoxy coating primer
D
duffymahoney
I have a talented tig welding buddy. He fixing all the casting pocks and smoothed it out. Next is glass bead it and epoxy primer powder coating.
D
duffymahoney
Hydroboost is going well. I hope none of the hoses leak! Waiting on FedEx for the brake lines.
D
duffymahoney
Glove box fitment is going decently. Bending the hinges seemed to fix all my issues.
D
duffymahoney
Now time to find and fix leaks.
I hope the ps lines don’t leak!
D
duffymahoney
Well no leaks. Now time to bleed my brakes. One of my least favorite things to do on a car. Anyone have any hacks?
