- Apr 26, 2015
- 2,586
Got my amp power steps in, now I just need to wire them. As I stated before I had issues fitting the 10mm bolts in the pinch weld, so I gave up and used 5/16 arp stainless bolts and put a SHORT nylock on the back. Since they weren't designed to have a bolt and nut you have to run the short nylock and cut the any excess bolt off to clear the steps. You can sadly see a little bit of extra hole on the drivers side I will have to live with it for now. I damaged some paint near, so I might have them professionally fixed. Passenger side went way better and they look way more clean. Using 5/16 makes these brackets work, without it would have been way harder.
Don't mind the discoloration on the raptor liner. I had the whole bronco professionally cavity waxed, they went pretty overboard, it's everywhere
But I like it better then rust.
