JuanGrande
I am looking at buying my first Bronco and I need some help figuring out the compression test. I went and check out a '69 bronco today and I did a compression test (I am very new to all this - I do have a '64 convertible caddy that I work on a little but...I am not a mechanic) on the motor. I only tested 7 out of the 8 cylinders (my wife was little pissed to be there since it was approaching two hours) and the compression ranged from around 120-125 to 130-140. Is this low? I know that if any one or more cylinders is significantly lower than the rest, that this is a problem. I haven’t been able to find a set number that the compression should be at – I saw a previous post by a member saying his compression was around 170-180. Any advice would be greatly appreciated.<br><br>Oh, by the way, I tested the motor by driving the bronco around for about 15 minutes, let things cool down about 10 minutes, and then one by one, I pulled a spark plug and tested that cylinder. I hope that I did this correctly???<br><br><br><br>
