- Joined
- Jun 8, 2010
- Messages
- 2,158
Well I’m finally giveing it a face lift. It’s done a lot over our years together with stock suspension. But I’ve recently worked my way up to 37s for trail tires, so the 3” body lift isnt enough anymore. The fenders got cut out in a big way last year in prep for OCBR, but it’s still got some clearance issues. A while back I picked up some parts fairly affordably that included 3.5 duff coils. So where I had been wanting to do 2.5 to keep it from being so y’all, I decided for the money I had in it, one more inch is nothing.
So here it is ready for OCBR last year.
I haven’t photo-documented this as well as I’d intended so far, but all I’ve done is change front and rear springs, weld on brackets for an antiwrap bar and new shock brackets, and restraighten the rear housing. So here’s some pics because WE ALL LIKE EYE CANDY!
Now here’s where the “fun” begins. I forgot to get some longer brake lines, so here’s what I did so that I could chauffeur the kids to the fireworks show tonight.
3/4” angle is my friend!
The springs I used are dealers that my dad has been running for about a year and a half. His bronco has sat too low in the rear since he’s got 5.5 springs up front, so I ordered him a pair of 5.5s to match and WH delivered them to LEBC RU this spring and my friend Shamu brought them home for me. So I’m getting springs that are already broken in! They also have some wedges attached, so here’s the drive shaft/pinion angle. (Btw, I’m running barnes4wd u-bolt eliminators on the rear housing too.)
It looks really straight but there is JUST a touch of bend at the joint.
Here’s the final product out and ready to go to town.
The plan is homemade long arms that adjust front pinion angle, grinding knuckles and adjusting caster, and I’ve got 14” travel Bilsteins for the front, using f250 shock mounts and 12” travel bilsteins for the rear using a homemade tall version of the vendors’ dual mounts. Hopefully I won’t have to cut into the body since it’s raptor liner’d inside and out in that area. I’m also considering copying Garberz’ track bar mount (mounted on the passenger knuckle rather than a track bar riser) but I have already bought a riser, also from Barnes4wd, so.... Maybe I can cut/use the riser as a drop bracket on the frame and get the track bar parallel to the ground? Then work on the drag link to make it all work together... also have a ram for ram assist that needs a mount on the housing.
Eventually I want to build a d44 pinion guard like I’ve seen on eBay for substantial amounts of moolah.
And then I’ll also need a hidden winch bumper to match the rear that I build last year after bending my old pipe bumper back at K2.
After all of that, I’ll be “done.” Oh, except for repairing the ding in the grill from the first trail at OCBR last year appropriately named “Can Opener.”. THANKS, SPAREPARTS!!!
Hopefully I can force myself to get the camcorder at to do some time lapses and stuff. But that sort of requires me to keep my shop clean and safe-lookin....
