- Feb 1, 2004
- 1,977
I am in a bind here. My BCB headers are causing all hell with my AOD cooling line placement. The AOD cooling lines have an adapter that goes into the transmission and then accepts 5/16 inverted flare. What is the size/thread pitch of the fitting that goes intot he transmission. Or does anyone make a 90 degree male inverted flare fitting? This is going to play hell on my remote filter/thermostat/cooler setup as I want to run it under the passenger area. I cannot get my tubing bender to make a tight enough 90 bend to get me by the header/exhaust. Thanks, BI
