Dirt Donk, Stephen, this goo is for you!
I started with a 96 bronco 5.8. I had 2 other blocks, a 70, and a 73 I think. I sonic checked all of the critical areas, and the late model was definitely the stoutest everywhere of importance---deck, main journals, cylinder walls, etc. The roller block also has taller lifter bores which is a good thing. The motors a wild horse not a pinto---ok. DD don't laugh please. CI, 408, stroked crank, h-beam rods 6.2 lg, chevy pin, arp rod bolts, 1 piece rear seal, cp pistons (bullet series) awesome piston for the money, and a great ring package. dart pro 1 cnc heads, small intake runner. ferera valves, isky tool room springs, mass flo efi, custom mechanical roller cam---.249 and .249 at .050 ,628 lift stait up, 112 lobe separation,Internally balanced, T&D rockers--1.7 in, 1.6 ex. External stock car products 1 stage oil pump. I saved 3" of taller ride height by eliminating the front lower buldge on the oil pan, caused by the oil pump being up front. If there are any questions about that I will expain it better later. The block was trued per machining, and the lifter bores were enlarged to accomadate .904 chrysler big wheel lifters. I'll explain more when asked about it. Super victor intake manifold, cometic head gaskets. 11-1 compression. the cylinder heads will allow premium gas with timing taken out of the motor. But i use the good smelling stuff. Remember I'ts not a daily driver. The oil pan was fabbed out of 3 pans, the main girdle and windage tray, custom built. That's why i have brain damage. UGH. But it all works good. Did dyno the motor---what a fiasco, Idled great but wouldn't get out of it's own way, kinda figured out something was way off with the fuel #s and such... Anyways the thing still made 525 hp and 500 flbs, never turned it more than 5500.. it wouldn't run. My motor guy says 685 and 570 ft lbs. I'm definitely gonna need help with this efi system... Trannys a full roller 6 gear planetary, hardened input shaft and some other stuff i can't remember. Finally pics.
