SavageBurro
- Aug 12, 2013
- 588
Hey everyone... I was extremely fortunate to work with Toms this last year to test out some prototype 4 link rear suspension.
I have done a fair amount of testing on and offroad and am super impressed with it so far.
My understanding is they will have it available for sale around the first of the year, with different options for different ride heights. The mid-frame brackets connect both the lower and upper rear links... they also provide a connection for their new extended long arms if you want to run them.
On-Road: superb ride over any bronco leaf springs I've ridden on (and ive personally owned or ridden on just about every bronco leaf pack out there). i would call it plush. Does have some body roll but not horrible. My setup uses slightly softer spring rates. I tested with slightly firmer rates that do provide slightly less body roll. If I were going to do mostly road driving, a sway bar would be recommended. Toms can provide all the 4 link calculations but I can tell you the rear does not noticeably lift or squat on take off. It miiiight have just a tiiiiny but of squat on hard takeoff.
Off-road: Wow. it articulates and tracks so well over obstacles. I haven't done a lot of ledges yet but the few logs and steep inclines ive climbed up and over it has zero issues with. It seems to put just the right amount of pressure on the tires for traction with no noticeable hop. I'm running 39s w 1" body lift. Flares are not cut all the way to body line but close. With the current 10" bilstein coilovers, I have the link set up to be equivalent to a 5.5" lift using 200lb uppers and 250lb lowers. I believe they are going to offer different bracket heights to accommodate different coilover lengths... or maybe even coil buckets for standard coils?
Quality and fitment of the links and brackets: Quality is excellent / beefy. Fitment on first prototype resulted in some minor improvements that they have since integrated. They basically changed a couple bracket angles by a couple degrees and raised the lower side axle brackets to be flush with the bottom of axle tubes.
Exhaust. I have a 2 into 1 exhaust that tucks up tight, fits around my 4R70w and atlas, that comes up and over the links then out the back corner... so exhaust fitment is very do-able.
Other than going fast through some deep potholes, I have yet to try it out offroad at speed like in desert woops.
If you're looking for a quality ride and performance out of your suspension - I highly recommend you give Toms a call and look into their new 4 link!
Mike S.
Mike S.
