PGreenlawMD
Help
Electrical is probably one of my weaker areas
New marine radio out of the box. no amp installed yet. Adding parts step by step to make sure everything is working
Wiring directly to battery; yellow constant power for memory directly to the battery with in line fuse and negative back to battery directly. Switch red wire connected to a toggle switch off the same hot line from the battery.
It works great EXCEPT when the power switch or toggle switch is turned off the memory constant on yellow wire keeps all the HUD lights and backlit display on which is draining the battery. Even taking the front faceplate off still leads to battery drain
With the stereo completely unhooked the battery holds charge fully with no measurable discharge for 24 hours
With the radio connected and the only electrical draw being the yellow constant wire I am dropping about 25% of the battery charge in the first hour alone
The battery recharges the 25% in about 10 minutes on a slow charge which is not normal. Battery measures 12-13 volts on charger and multimeter.
First, battery must be bad so tomm will get a new combo starter/deep cycle battery. Battery is 3.5 years old
Second, any other way to wire this radio in not using the ignition switch (long story but can't use currently). Am going to call tech service for HUD unit but want to have exhausted most reasonable things prior to being on hold forever
