Leaking Advance Adapter D20 to M5R2
Yeller
Rogers County Oklahoma
Often in the past I’ve had to get 2 single seals and install them back to back. Don’t remember that part number anymore sorry
Timmy390
Timmy390
Conway, AR
Thus is the info I have. ViperWolf1 posted it back in 2015
Current seal info: Input shaft seal (double lip)-CR #517383,Napa #NOS 18676, CR #18676 (good seal) (Do not use Timken #473179)
Tim
EPB72
Pleasant Hill, CA
Just ordered 2 from WH, got them and checked them both were double lips single spring, sending back. #18767 is the right one, no luck here in utah. 18676 is correct#
Asmith have you tried Novack conversions thats where I got my correct double lip and spring seal ,AS my Tcase kit came with the single spring seal and didn't fit the AA adaptor ,,,
Tim how are your adaptors set up in my case the seal only stops transmission to transfer case fluids from mixing and wouldn't cause an external leak since there's a gasket at trans end and also at TC end that would stop the external leaks
Timmy390
Timmy390
Conway, AR
The M5R2 and Dana 20 can't mix fluids. The extension housing between the two is dry. M5R2 tail shaft has a seal then the 5 or maybe 6 inch long extension housing then the adapter spud shaft and ring then the seal for the spud shaft. If fluids from either the trans or D20 leak it will drip between the adapter ring and the extension housing. One can't enter the other
Tim
