I've recently had a lot of help figuring out a solution for an oil leak coming between the back of my intake manifold and engine block. It looks like I'll be pulling the manifold off and installing some new gaskets. Unfortunately, that doesn't seem to be the only source of oil leaking from my engine bay. As of recently, I've noticed more oil leaking from under the hood and it is hard to pinpoint where it is coming from. The majority of the puddling seems to be happening from the driver-side of the engine bay. There is so much grime and dirt that it isn't easy enough to just find a few drops of oil and go from there.
So, here I am, once again, asking for your help and patience as I try to figure out how to stop dispersing 5W-30 around my town. Where should I begin? Are there hoses I should be looking at for replacement? Is it potentially the header covers and they need a new gasket?
I've attached some bad photos; my plan is to get the Bronco on some stands so I can really get under there. I can provide as much info/photos if requested. As always, thank you for your help in resolving this.
