clintonvillian
Well the old girl is running pretty good. As stated in some other threads I am going to rebuild the carb. I have some oil leaking, so I am going to chase that. I want to go to a duraspark II ignition and get rid of the points. I also have a cracked manifold so I need to redo them as well as the exhaust.
I plan to do a complete frame off in around 5-10 years on this ride. So I am on the fence as to what to spend my money on now vs go cheap.
Below is a list of items I am replacing/redoing now to keep it on the road.
-Rebuild 4180 Carb
-Intake Gaskets
-Valve Cover Gaskets
-Valve cover breather caps
-Waterpump and gasket
-Heater motor
-Heater valve
-Headers or manifolds, (this is an area I think I should go cheap, and save the money for a Really nice set when the motor is rebuilt), I'm thinking cheap headers, if you go headers doesn't the dipstick tube bolt to the stock manifold?
-Exhaust, again probably a cheaper aluminized kit and save the money for a stainless exhaust for the rebuild. I'm thinking Duff has a decent priced kit.
-Duraspark II Distributor, Painless Harness, Coil, module
-Plug Wires
-Plugs
If there is anything else I should be changing, cleaning, etc while I have it torn down this far, or advice on anything, I'm all ears.
-Rebuild 4180 Carb
-Intake Gaskets
-Heater motor
-Heater valve
-Plug Wires
-Plugs
