- Apr 19, 2014
- 2,344
One of the benefits of being turtle slow is that it gives you time to think about 'How'm I gonna do that?' Case in point is the J-shifter for the Dana 20. I started pondering on what TC shifter to use a few years back and bought a few T-shift and J-shift linkages to aid in the decision-making process. I nixed the JB Fab twin stick option due to 1) being too much Dutch, and 2) there's already one on every street corner.
I took all three of the J-shift linkages I had apart and evaluated the good and bad of each and decided to try going with an over-sized 5/16 hardened dowel. First, I selected the cupped mounting bracket that came closest to fitting a 5/16, one that was close, but no cigar. I then took a round fine file and cleaned up a few burrs so that the dowel fit nice and snug. I then selected a shift lever that was not overly warn out. Next, I used a Dremel and a file to make the ball socket groove wide enough to accommodate a 5/16 dowel. I 'snuck up' on it so as to not end up back where I started. Then I put the pieces and parts back together and it seemed to work fine, just fine! I tried to video how much smoother and tighter it was, but wound up with video of my shoe. Took the pieces apart again for painting and called it a day. Howard in Beautiful West Michigan.
View attachment 877145 View attachment 877146
