Bronco73
I am not sure on this but it seems like the earlier broncos may have come with a different flare on the brake lines, inverted? I have a 71 with a D30 so I can assume it has the inverted flared lines?
My question comes from searching the T-bird caliper swap. I see people mentioning buying 4x2 (1976?) front brake hoses for their disk brake swap. Are they buying these hoses because of the different brake line flares or are they buying them to fit the T-bird calipers or both?
Is there a reason to not buy the stock T-bird rubber hose for the T-bird caliper swap and is there a reason not to buy the stock 78/79 rubber disk brake hose for that caliper option?
If I can buy a different hose instead of adapters then that would be a better way to go, less parts to screw during assembly.
