SelectiveSlug
- Oct 1, 2023
- 10
Hello EB Community! I'm hoping the EFI experts can help me out as I'm struggling to diagnose my Bronco.
Bronco Details:
1989 Mustang 5.0 Ron Francis harness, factory computer. C4 Auto. This setup was installed roughly 10 years ago and it used to run perfect. About 5 years ago I decided to park the bronco and redo the suspension (was supposed to be a winter project, yikes). I finally finished the suspension, started the bronco up and drove it to my new garage. It then sat for about another 9 months. I went to go start it and it will not fire up. I have spark and it cranks just fine.
Fuel System Details:
One low pressure fuel pump mounted near a stock tank and an in line filter. Quart size spin on filter mounted on the firewall and then a high pressure pump on the inner fender. AN Lines after the high pressure pump and a return line. Factory ford stock size injectors new when installed 10 years ago.
New parts purchased in the last 2 months:
Fuel tank, sending unit
high pressure pump - reads about 38 psi
sent the computer to be rebuilt
Fuel pump relay
idle air bypass
Noteworthy:
I have power at the injectors but the are not pulsing when cranking.
When I pull the ECM relay the fuel pump runs, when I put it back in it stops and I lose power to the relay.
I found the self test portion of the harness but I cannot figure out what to do with it. Is there a way to plug in a OBD scanner to it? The harness instructions mentioned:"Locate the V.I.P self test connectors and connect a jumper wire between the grey wire (VIP->CTS SPL) located in the large VIP connector and the tan wire (ECM 48->VIP) located in the single connector" - I am not sure what they mean by connect a jumper between the wires, does this trigger the check engine light to flash the code?
It feels like the computer is bad even though it was just rebuilt. Or the only other noteworthy thing I can think of is since it sat for a while, the rubber inside the AN lines may have come apart (when I first started it I had to replace the line directly after the high pressure bump as it was leaking) and may have clogged the injectors?? But then again they aren't plusing so I think its more of an electrical issue. I didn't touch the harness or grounds but it could also be possible a rodent got to it. Everything appears to be fine visually.
I appreciate any extra insight!
Bronco Details:
Fuel pump relay
idle air bypass
Noteworthy:
