pcf_mark
- Jun 11, 2010
- 3,584
I have all '92 Ford OEM parts in my EFI system I just control it with MegaSquirt. I have two issue both I think are related.
After driving and shutting the truck off I get a distinct fuel smell. It seems to be more toward the rear of the vehicle but it is pretty strong for a while afterward and I have no fuel leaks. I checked the fuel pressure and once the engine stops it drops to zero pretty quickly. I have a newer pump with the check valve. I had assumed it was a leaking fuel pressure regulator. However when I go to re-start it the engine is very difficult to restart. Stutters, stalls, rough, smells rich for maybe 20 seconds and if I try to rev it up sometimes to will clear up but usually I just wait for it to smooth out on its own.
I am now wondering if I have one or more leaking injectors dumping the fuel into the engine when I shut it off? Any way to test for this?
I have also some luck by turning the key on / wait 10 seconds / key off / key on wait 10 seconds to let the fuel pump run. I think when the fuel pressure drops there is very little fuel in the rail to start the engine causing EFI to be pretty confused. If I do that a few times when it is hot generally it will re-start ok.
Thanks for any good ideas you can share.
Mark
Mark
