Ok, let’s hear your tricks. This would definitely have been easier with the engine out but I didn’t know that in my order of operations. Seems my life is full of parts with poor instructions but I guess that’s what keeps your brain working.
I removed my never used Duff Shock Hoops and putting on the newer towers and running their single Eibach shocks and need to drill the holes through the frame and the holes have to be IDENTICAL on the other side of the frame as the support bracket. Copies the boot holes from the tower.
I first drilled the holes on the outside:
I went one by one and put a bolt through the hole. These holes are tight and no room to get it wrong. Stressful.
Then, I put BOTH rear plates together and used those as a guide to help keep my bolts as straight as possible and I used my 1/2” bit to make an indentation on the opposite side and proceeded to make the holes with a series of bits.
Two holes are perfectly aligned. One is close, and the other has another hole right next to it so I’ll have to get in tight with an angle driver with the plate on the other side.
What would you have done to get the holes closer to perfect? I do think this worked as well as possible, but curious. The other side will be a little more stressful as there is less room beteeen the gram and pass side of the engine.
I plan on using the same guide but adding this little homemade drill guide I came up with (I need a different fitting and I’ll drill it out to 1/2”):
But I might need some longer bits for that.
I have a little portable drill press attachment thing but the spring tower is in the way.
Like this:
Like this:
