Nice work on your project.
What fresh air system are you using?
After using it did you have any problems with it?
Thanks.
For the engine I made a filter housing from a V8 diesel. You can see it in post 79. Fresh air for the cab is all stock. I cut stock looking slots in the hood. I haven't had any probelms with either fresh air system rolling it from the shop to the driveway.
Doug
Oooops, my mistake. I had just looked at your fresh air painting mask system pic and I posted. I should have specified.
I liked your caption under it by the way. If you've never painted you don't know how hard it is to wait for the paint to flash.
It's like watching paint dry. lol
This thing is looking awesome.
I'm getting ready to drop the motor in mine. I'm not quite sure where to land it vertically.
If you don't mind, could you tell me the dimension you ended up with from the top of the frame rail to the top of the front valve cover?
Also, it looks like you're using the highlander hood. How much clearance do you have between the top of the valve cover and the bottom of the hood?
Did you offset the centerline of the motor towards the passenger side?
Thanks in advance! Any help would be greatly appreciated!
Andy
Are you going to add an AC unit to yours. I didn't remember if your a open top or not.
MINE does not have the P PUMP .. bUT THE OTHER CHEAPER PUMP I don't remember what it's called .. VE I think but I have 2 injection lines going across between the 1st and 2nd valve cover. I NEED THEM LOWER so I can reroute my air inlet tube forward .. So that I can add on an AC COMPRESSOR jUST OVER THE POWER STEERING pump.
..... Did you do anything to lower those injection lines. OR where your with the P-Pump just out of the way.
I laid a strait edge across the left and right frame rails and the center line of the crank on the diesel is 3/4" above the strait edge.
I also have tons of room of clearance. I may have to take out my body lift.
Dbteak.
Can you get a measurement of your driveline angle front to back? I've been trying to determine if mine's too steep. 8-ish degree right now. Zero running issue but I want to get it at 5 degree by raising the TC.
Thanks,
Eugene
where did you get the intake plate with the pipe aimed toward the radiator. My original plate had the tube pointing up. and I made a 2nd one that points the tube out toward the driver side fender . But now for the AC install I need it to point toward the radiator.
I looked for my magnetic angle finder and I can't find it. As soon as I come across it I will get the numbers to you.
Doug
