how can i order a set for my 69
If in Corpus Christi, shipping is $37.66, total would be $232.66. E-mail me to set up details rcarlson@usemco.com or call 608-343-0713.
I'd like a set... Please PM me a shipping quote to 94551. If you are no longer making them for lift off hinges then I would like to get them shipped without hinge provisions so I can adapt my own to them. If you'd like I can share some pictures of my own designed lift off hinges to fit the WH stainless style hinge. I think covering these in canvas would be sweet for keeping at least some of the mud and muck out when running doorless.
-Tony
Mine are "Lift-Off"!
I did not spend the money to do that....you can easily make it so that they come off!
Drilled out the hinges to accept a 5/16's nut and bolt set-up! BADA BING! - BADA BANG!!;D
BUT I keep them bolted on with a nylon lock nut to deter/discourage possible thieves....JMO
any news on the insert doors? I am interested in some for mine
I have seen sevaral people ask about inserts? What are they? If it is a cover to keep the elements out I would think they would be super easy to make out of aluminum.
They could attach with spring clips, just pop rivit the spring clips to the aluminum. You could leave it aluminum or paint it. It and would be easily removable. You could use the diamond plate style or do a swirl finish on the aluminum with a metal brush and drill motor.
I would do it but really don't need it here in Calif. the deserts just don't have too much mud! heh-heh;D ..plus I like sticking my foot on the tubes as I drive!..The skins would get in the way of that treat! heh-heh;D
They're referring to fiberglass door inserts, like the ones that came on roadsters. People are waiting for tube doors to fit these inserts. They are the white part in these pictures:
