Build Thread (PaPa Smurf)
bronccar
Name is a work in progress lmao
After collecting, parting and selling for 14 years I started my build this week. I made some crazy assed promised about Super Cel '17 that I am trying to keep in spite of a few set backs.
I will have a ton of questions and ask for advice - so TIA!
Here's where I am today (don't laugh)
Here's the specs / what I have purchased / planned for:
76 frame
Blasted awaiting Por15 and Paint
Rear end
BB 9" rear 4.56 gears
31 spline
Detroit
JBGY Rear Disc Conversion
Status: Need to paint and complete assembly
Front end
Dana 44 Disc
Trac-Loc
4.56
Status: Need to replace ball joints and U-joints / paint
Suspension
3.5" lift (JBGY Coils, Deaver Leafs)
Duff Stage 3 extended Radius Arms
Duff Stage 2 Hoops
Duff Stage 2 Rear Shock Mounts
Duff 70/30 Shocks
Adj Trac Bar (Duffs)
Status: dry fitting components now before painting frame
Drivetrain
C4 Trans (rebuilt), winters shifter
3.8:1 Atlas II (on order)
Long Travel Drive Shafts (duff)
Status: Trans done, awaiting Atlas, ordering DS after assembly
1973 302 with 92 Mustang EFI (harness with Brian right now)
Needs freshening up (I need a good mechanic)
Status: Think I found a guy to work on it a bit.
Electric Fan
Aluminum Radiator
Derale 13900 Trans Cooler
Oil Cooler TBD
Steering / Brakes
79 Econoline Tilt Column
HEIM joint steering
4x4x2 box
Saginaw pump
Hydro-boost
15x8 Procomp 99 series flat black 8 hole steel wheels
35x12.50 / 15 Tires (TBD) looking at several
Thoughts on Baja Claw?
Will do some crawling, trails, mud, street, little highway
Body is more or less an afterthought. Basically 67 tub, decent shape tubed to radiator support
Family Cage
Want harness suspension seats but my ass is wide
Thoughts on Seats?
bronccar
bronccar
Current Questions:
76 9" housing had the drop in seals in the housing, but the new axles have the tapered bearings with the seals on the outside so the inner seals aren't required, right?
Fuel Plumbing:
Love to hear your thoughts. I am running single tank (poly for now until I can afford to have an 18 gallon aluminum built). Looking at SS hard lines with braided on the ends or running braided the whole length.
Thanks!
edones06
Lookin good man! Holler at me if you need a hand ill come help ya out if i can.
bronccar
bronccar
Thanks man, I'm gonna take you up on that.
I'm waiting on the train, just talking to Wayne O about you lol
surfer-b
correct, remove the stock seals, the gear oil lubs the bearings on the tapered set 20's
sprdv1
REBEL
Good stuff, Look forward to your build. Gotta start somewhere, Why not at the beginning :")
bronccar
bronccar
Thanks and that's exactly right.
I got a bad case of the "while I'm at its" and that led me to a bare frame LOL
sprdv1
REBEL
LOL, nothing wrong w/that, it will be awesome when you're done.
Just be patient, there will be hiccups :)
Crawdad
I'm not too far ahead of you!
I suggest you buy allot of beer and invite or make allot of friends if you planning 2017 events.
Other than that get a big ass white board and list everything you need to do and erase things as they get done. Stuff pops up in you write it down on the white board so it can be properly managed. Leave a section of the whiteboard for buy it lists. Some parts can get hard to get right after the Christmas specials and at the start of spring. Your shotgun approach to refurbing the whole truck can leave you all hung up with multiple missing parts. Buying and shipping logistics can be worse to foul up your plans than the actual manual work involved.
bronccar
bronccar
Wanna race Crawdsd ;-)
Rusty truck I know it's ambitious to say the least. I've got some good EB guys in my corner so that will help.
And the bay door in front of the chassis already has a list started on it in mark erase :)
dave67fd
Nice to see another build starting. Good luck with it and keep the faith.
bronccar
bronccar
Thanks Dave!
Got my frame lined out (had to repair behind the rear shock mounts).
Going to start coating the frame next week and hopefully assemble the rear end.
Switch over to 2004 mustang hydroboost, got the Ebay kit with the adapter and linkage.
Have been sent the wrong 4x4 box twice for the 4x4x2 build, still trying to decide if I want to stay on that path...
Tomjfred
Hi all- new to the forum and looking for advice. I've got a '72 bronco that I would like to start carrying 1-2 kayaks on in short distances. My question is, does the roll bar and windshield (particularly the windshield) have enough support for the kayaks or should I look into getting a 4pt cage for behind the seats to better spread out the weight of the kayaks?
Thx, Tom
bronccar
bronccar
Tom, you need to post your own thread for this question to get meaningful responses, but I wouldn't recommend putting the kayaks directly to the windshield frame without at least bracing the frame to the roll bar so it doesn't bounce. Much better off with a different cage to carry the weight.
bronccar
bronccar
Getting there man. I'm gonna holler, planning a build weekend with a few guys coming in from out of town if you're available
