Desert Thrasher
- Jul 14, 2001
- 2,353
It's been awhile since I've updated this build thread. I just fabricated a new transfercase crossmember. The first one I built worked great. However after some hard abuse, lots of using it as a pivot point on large boulders and big concrete tubes, it had actually bent upwards and was touching the Atlas. I knew I had to remove it and build another. So instead of 1.5"x.120 wall square tube, I used 1.5"x.250 wall round DOM.
Also this time instead of going flat across the frame I angled it up just after the tcase. Hopefully this will help with ground clearance some. I wish I had a 1.5" die for my tube bender but they are expensive and I only have a 1 3/4". So it is built out of 2 pcs welded together, still better than the 3 pcs from the first one though. I still need to attach it to the TMR tcase support, but that should be easy enough. This time I really need to build a skid plate between the transmission and tcase crossmembers. That probably would have saved the first one by spreading the load between the two crossmembers. Anyway here's some pics.
