Desert Thrasher
- Jul 14, 2001
- 2,353
I got the Anti Rock Sway-bar installed on the rear of the Bronco and WOW what a difference it makes driving on the street. No more body roll, I can actually go around corners without white knuckling the steering wheel. It’s actually pleasant to drive around town. I still need to test it Offroad, hopefully I’ll get to do that soon.
With over 20” of travel it took some work to get the sway bar setup properly. I had to remove the coilovers to check it at full bump and full droop for proper operation. At full droop it is close to max allowable angle suggested by Currie. The end links are 16” eye to eye. I plan to sleeve them for strength. I think if I had mounted the sway bar under the frame it would have been easier to setup, but it all worked out. I can’t wait to get it on some rocks and see how it performs now.
