Bought a 2000 ford explorer for swap
chuck1022
I have been really enjoying driving it. I have been tinkering with it and found the coolant crossover pipe has a pin hole in it. Anyone replaced one of these before? What's the PIA factor?
That is also a sign that when you do the swap, change all the core plugs in the block. They are only a little thicker than the tubing and are probably pretty crusty inside. So much easier to do while the engine is out and only a few bucks for a whole set.
Weather you want to do a preventative change of the timing cover...
C
chuck1022
I almost have it all torn down. So far I have only lost 2 half inch nuts.!!!!
Anything I should change while I have it torn down.?
Seems to be a lot of black soot in the plenum chamber
904Bronco
San Martin, CA
I always changed the timing gear set, new water pump, and new oil pump. Clean out the oil pan and it gives you an idea on how well the oil was changed...
As mentioned above, consider the freeze plugs, best time to change them is now.
C
chuck1022
Ok.....been working on it a little every night. Got everything off but plenum.
QUESTION
is there a gasket in between the plenum and intake????
BanditBronco
QUESTION
Yes, it technically only moves air, so I tend to reuse them a time or two. I would start with a fresh one for now though
C
chuck1022
Ok....I ordered the part and this came in. I unscrewed mine from the manifold....this looks pretty damn close.....minus the threaded part that goes into the manifold
C
chuck1022
Should be a jam nut type thing there
C
chuck1022
Somebody has run into this before. In all fairness...I should be asking in the Explorer forum
4x4man514
Augusta,Georgia
i had the same question not long ago . the bolt on the bracket is all that holds it in there. i guess the pressure isnt enough to blow it out
4x4man514
Augusta,Georgia
thats right. as long as it will come off. i had one set of pipes that the end of the pipe was flared so the "nut " would not come off. so i had to buy a new one and it just slid on over the o rings. it was a tight fit.
so yes as long as it isnt flared you will see once you remove it it will look like your new pipes.
904Bronco
San Martin, CA
You know it was just a week or two ago that someone brought up this same issue with the new pipe and extracting the fitting off the old coolant pipe....
Sorry I don't remember the tittle, but I will do a short search...
C
chuck1022
Got it all apart!!!!!!
Is that orange thread lock on the nut that goes into the maniford????
Blue 242 thread lock but I saw red stuff too
904Bronco
San Martin, CA
It is a thread sealant, not red loctite.
You can use teflon tape, thread sealer paste, etc. Make sure the threads are cleaned up some on both ends, and you can crack the aluminum on the lower intake if you get a little overzealous in screwing the fitting in the manifold...
