Privatebrian43
Newbie
- Apr 18, 2021
- 15
Hello Again, I've installed the CJP exhaust system and it worked out great. Was able to use the original hangers.
Now I've moved on to getting the engine to run a little smoother. Tested dry compression and it was (in order 1 to 6) 125,100,110,133,130,130). So I thought I would adjust the valve/rocker clearance. My Chiltons book says both intake and exhaust are 0.018", so I used a feeler gauge between the valve stem end and the rocker, adjusting the "nut" on the other end of the rocker until I got a snug gap. Compression improved to 130,138,165,140,136,135, but there was still some ticking/knocking.... now the rub - I was watching a Youtube vid on 170 cid valve adjustment on a 65 Falcon, and it was set to zero lash (push rod spins but won't move up or down, PLUS a half turn IN on the adjusting "nut"... Maybe this is specific to hydraulic lifters (?), I was using the procedure from my flat head jeep (42) that has tappets and no push rods... probably a mistake. So my question is - would a 66 170 CID Bronco engine have hyd lifters or solid?, and is the zero-lash+1/2 turn in correct, if so, why would Chiltons show a gap value?
Thanks for any comments,
Brian
Brian
