2 belt alternator pulley replacement
roparsons
I have a 1975 Bronco and need to replace the alternator. The current one has a 2 belt pulley and I’m wondering if there’s a way to remove and reuse it or if I have to buy a new one. Thank you!
m_m70
Pacifica, CA
you should be able to reuse your pully. just make sure the shaft is the same on your new alt. impact wrench is the easiest way to remove the large nut that holds the pully on.
