smaller pulleys will squeal easier than larger ones there are pros and cons.
Smaller pulleys spin the alt faster and create more charging power at lower engine rpms. the down side is that the belts squeal easier, they use more horsepower, they wear out faster, and high engine rpms can destroy the alt.
Larger pulleys spin the alt slower, which = lower output at idle and lower rpms but you actually have more belt contact with the pulley combined with higher leverage making the alt easier to be turned by the engine. This makes the belt less prone to slip and make noise.
For example, I'm running a 2 7/8" diameter v pulley with no issues on low rpm output or belt noise. If your pulley is smaller than 2 7/8", you might consider trying a bigger one. I kept looking in self serve wrecking yards and picked up a handful of pulleys in various sizes. Then after experimenting chose the one that worked best for my purposes. I would love to go serpantine on my engine but cant afford it right now.
weather the alt has a large or small pulley, charging system demands also play a key factor on if your belt will slip or not.
~BH~
