1972-73 owners-mind your P's and Q's
Oakland Bronco
San Francisco, CA
Hmmm...I think the P was a 72, tho I considered it a 73 being that it was a PS rig and a Ranger. But regardless of it's past it is now a 72 for sure.
The Q was titled as a 73. It's fully restored and in Japan....but I know it very well (body off resto).
Viperwolf1, I haven't forgotten about this. BajaBronco has my rig -- a '73 with VIN Q52289 -- so unless Andrew can chime in with month/year built, I'll get that info next week on Tuesday or Wednesday when I see him. Actually, come to think of it, I ordered a Marti report 3 days ago, so I should get the report back today or tomorrow. I'll post the details when I have them.
Another registered '73. Q84469. No decal, so month will have to be determined.
Light bars, power steering and auto trans. J-shift, return lines in the sending units, but not on selector valve. However, that could have been changed. DSO 72 in case that can put anything in perspective. Didn't look for ambient switch, but am helping put it back together after a full frame off, so don't know where I might find it. Door hinge pillar could have been covered.
AZ73
Wow, I had to look up what an ambient sensor is. When I was dissembling the Bronco I wondered what that was. I'm assuming now that this is it, and if so, my Q235 has it.
Viperwolf1
Viperwolf1
electron whisperer
One of the earliest J shifters. Supposedly started at Q80000.
I can understand the senders having return ports. Ford probably ordered a huge number of them at the begining of the model year.
If it ever had the temp sensor the screw holes would be tapped.
ransil
is it possible to have an "M' on a 72??
M67312
I have the vin in my phone I will need to verify it against the vehicle.
ambient temp sensor
t-shift
Viperwolf1
Viperwolf1
electron whisperer
M67312
ambient temp sensor
t-shift
Yes, early '72. M67312 looks like Sept '71.
nmgearguy
Here's an early 1973 for your database
registered as a 1973
build date 11/72
VIN Q63450
T Shift
Auto tranny
Dash lights
return line at the carb, 3 way at selector switch
no temp sensor, has a rubber plug there
Hope that helps
Viperwolf1
Viperwolf1
electron whisperer
build date 11/72
VIN Q63450
T Shift
Auto tranny
Dash lights
Hope that helps
That's a key puzzle piece. Any chance you can get a pic of that return line at the carb?
Viperwolf1
Viperwolf1
electron whisperer
That's it. Did you 3 speed have a switch screwed into it in front of the shift levers too?
Stingray240cs
Corinth, Texas
Oh, I missed that. Mine is P89210 1972 J shift 3 speed with amb sensor.
I was wondering what that was.
If you need more info let me know.
Sent from my Droid DNA
Viperwolf1
Viperwolf1
electron whisperer
Is that sensor in the drivers door towards the front of the bronco and top of the frame?
Yes, just like in AZ73's pic above.
Just for more clarification. The sensor is the metal thing with screws. The hole was there forever after '72 so it was just filled with a rubber plug (no screws) after it was discontinued. The rubber plug is not a temp sensor.
Stingray240cs
Corinth, Texas
Here is a picture, don't mind the mess...
What mess?
Isn't that what they all look like, at least at some point in their lives?
Looks pretty familiar from here anyway.
AZ73
Cool.Even has the Gabriel Adjustable E's in it!
Your trans may not have the switch, but the plug is there in the front near the bellhousing it looks like.
Wonder if it was removed, or never had it. Either way though, the tranny is correct vintage or it would not even have had the plug.
Wonder if they changed the designation too? As in "RAT" and "RAN" and "RUG" and maybe another one?
Viperwolf1
Viperwolf1
electron whisperer
Don't think so. Here's a pix:
I can't tell if that's a plug or broken switch. Here are some reference pics. Note the D2AR casting number.
nmgearguy
Sorry Viper those parts are long gone. I do remember that there was a single hard fuel line coming from the fuel pump and ~8" from the carb was a return split (or "T"). The section of the split that went to the return was factory bent back towards the fuel pump and was blocked by the P.O., while the other section obviously went to the carburetor. Since the P.O. terminated the return line, I have no idea where it went from there. I only assume it went back to the fuel tank, but with two tanks and a 3-port selector (not a 6 port) valve, I'm stumped. Hope I didn't just confuse things more than not.
Thanks for collecting the data. It's helps us all and I appreciate it.
AZ73
Looks like a plug. Couldn't tell you if it used to have a switch and they plugged it or the factory plugged it. Don't recall any dangling wires down there.
