What have you done to your Bronco today?
Scoop
Have Bronco, Will Travel
Cuchara, CO
Finished up some work on my crawler in preparation for the Texas Round Up next month -
- I had my driver's side spindle bolts pull out of the knuckle so I drilled and replaced all the bolts with grade 8 bolts and nuts on both sides.
- Packed the front wheel bearings, new spindle bearing and new seals.
- Installed new front driver's side brake line and new front brake pads.
- Finished the install of Moser axles up front and rebuilt the Superjoints.
- Installed a WH Wrap Trap.
Should be ready to go!
Z Bronco
Cleaned up one of the Explorer Throttle bodies. I two different styles, one early and one later TB. Tomorrow I will start cleaning up the other one.
sprdv1
REBEL
Busy man... I got to make some time soon... first need to order couple new wheel spacers, Finally found a decent deal
Z Bronco
Finished cleaning the Explorer Throttle Body, changed the TPS plug to the Mustang one, and turned the vent tube 180 degrees.
willtel
Finally got my cooling system flushed an cleaned. What a pain.
I also put a glass section in the upper radiator hose so I can keep an eye on the coolant condition a little easier.
Hose by willtel, on Flickr
tasker
all knowing of nothing
NH
fetched my c4 and dana 20 to be reinstalled after a rebuild....if this snow ever melts!
tasker
NH
JUST a heavy dusting last night....
