- Jul 15, 2012
- 34
I have been trying to finish a lot of different mods to my Bronco. The latest is a NP435 to ZF5 swap on my EFI 5.0 . IM getting a bad vibration parked in neutral between 2 and 3 grand I used my old flywheel but bought a clutch kit from Rock Auto for a 1992 F250, to get all other related parts, (P plate, disc,master, slave,T.O. bearing and pilot. I also had a shop rebuild the ZF. The first few times I started the truck after the swap, the trans was rattily and still is. But I herd that this is not uncommon. (filled with Mercon) My First question is, do pressure plates have a neutral balance ? not specific to a 28 or 50oz imbalanced engine? Or do think my rebuilt trans has a input shaft bearing problem? vibration and sound change when operating the clutch at RPM. Thanks for any help, Gary
