Rustytruck
- Feb 24, 2002
- 10,875
I''m missing the rubber pressure valve tube
You mean the vent on top of the adapter housing? If so that was a steel fitting with a loose metal cap on it. You can't plug that. I tapped my extension for a elbow fitting with a tube nut and then ran the tube all the way up to the firewall next to the other transmission vacuum tubes. That alone kept it cleaner down there. Plug that vent and you will be leaking fluid all over the place when the fluid heats up and expands.
