Hey All, I have a stock 302 and Carter 4 barrel (basically Edelbrock 1405) and it’s awesome. Changed to off-road needles and seats and blocked the fuel passage to each bowl and it’s been great off camber, during climbs, and descents. When putting around about 8000 feet I turn my idle up a turn and back out my mixture screws 1/2 turn and there are no issues. Yes, it’s a little rich and there is lack of power but it doesn’t warrant me throwing in my next set of metering rods and springs. Maybe if I were tooling around at 12k feet I’d need to.
At home, Phoenix area, cold starts aren’t an issue whatsoever. Full manual choke two pumps of gas and she fires right up. On my last trip in the mountains it was extremely hard to start in the morning. Both mornings were about 25*F. I tried full choke combined with fuel which eventually flooded it. Tried no choke and pedal depressed to floor with no luck. I was cranking so much that I threw my jump pack on the battery just to make sure I was getting full cold cranking. Battery was fine. The second night I fired it right up before bed thinking maybe the block wouldn’t be so cold in the morning. Aside from waking up in the middle of the night to start it I’m out of ideas.
I’m just not ready to switch to EFI. There has to be tips or tricks to starting in these conditions. What do the members with more wisdom than me do? I was reading about pulling a vacuum line to allow more air in the engine when starting. Of course there is starter fluid, but don’t like that idea. Does anyone have some suggestions?
Thanks,
Mike
Thanks,
Mike
