dixie4x4
Ok, ok I need help. I also need advice on my bronco.
I am doing a full custom front end suspension. I plan to install hoops, new shocks, and new springs. My question is a many part question...
First of all, if I have a shop install the springs BEFORE the rest of the build, can get away with not messing with brake lines or anything else. They would do it cheap enough that it would be worth my while to not mess with it myself. Springs make me nervous.
After the new springs are in, can I take the truck to a friends house with a cutting torch to remove the old shock mounts and drive it without shocks? How far would that be possible/bearable?
Am I correct in assuming once the springs are in, there is no real danger in the suspension system? I can freely remove or install anything I want at that point without worry or having to get too technical. The shocks should have no sprung tension, so I can remove them without jacks or anything on the frame, right?
Thanks a lot for the help with any of the above questions, I have done a couple newer vehicles suspension modifications, but pre-coilover is before my time and I hate them too. I want to do it myself (minus springs) to learn the suspension system better and to not pay the ridiculous price I expect to be quoted to break out cutting torches and welders.
