- Dec 21, 2019
- 28
Newbie here and i'm learning as I go...I'm converting my 74 with a 351w to sniper EFI. Going with the Sniper 2 kit that was just released. Wanting to retain the stock tank for now to save on funds. I don't plan to drive long distances so figured going with a 23 gallon tank is overkill. I've done a lot of research and I'm aware of the pros/cons of the intake pump vs external pump. With the external, im concerned with noise and heat. I know many have had success, others have not. There is probably a way to cut a hole in the top of the stock tank and drop an an in-tank pump in?
I came across this on Holley's (PN 12-305) site and wondered it it would work with the stock bronco tank? It's for a mustang but im thinking it might be compatible. Holley was no help. It basically uses a sending unit as the drop in pump. If it fit, it would eliminate the need for a return line, has a built in regulator, and could be accessed without removing the tank thus elevating many of the external pump concerns but with minimal fab and install work.
https://www.holley.com/products/fuel_systems/fuel_injection/sniper_efi/ignition_and_fuel_systems/muscle_car_efi_modules/parts/12-30
Any ideas?
Any ideas?
