H20rider
Newbie
- Jul 14, 2021
- 84
I’ve searched “loose”, “floppy”, “repair”, etc. for vent windows, and there is lots of info about springs, tightening the spring retaining bolt, replacing the washers, etc. However, I cannot find a fix for wind wings that remain floppy when the spring bolt does not rotate. If I hold the bolt from below, my vent windows have some play in their open/shut movement. I don’t think the spring bolt that connects to the bottom of the vent window-glass frame is sheared off, because there is only about 15-20 degrees of free rotation. That means that I get free movement of the vent for a couple of inches, then the proper resistance (due to the spring) sets in. Once I let go of the window, it still has 15-20 degrees of rotation but at a new spot in the opening rotation. More concrete explanation: I unlatch the window. It will openn2” without any real resistance. Then if I push it open more, there is proper resistance. Now, letting go of the window, it stays open, but flops around at that ne position.
I have thought about dismantling the vent window, but before embarking on that endeavor, I wanted some idea of what the actual problem might be. Ideas?
