Hi,
I keep forgetting to take pictures but there was a camber shim (I think) under the nut for the top ball joint on one side of my bronco. It looks like an angled washer, taller on one side. I replaced the ball joints, do I need that on there or should I take it off? I put new front end parts, linkages, disk brakes in so I need to take it in to get aligned and need a good starting point.
I have found the center on the steering box what do I do next to get it close enough to drive a few miles to the alignment shop? I have the BC bronco tech note on setting toe in but is there any way but eyeball to get the tires pointed in the right direction?
Thanks,
Jason
Thanks,
Jason
