bronco loco
It never ends
Good morning, I have a 1978 f150 front differential that I will be removing from the knuckle outwards to replace Leila's bronco front drum brakes. The left spindle has a round camber shim. This is my first time doing a disc conversion, and need to know if I should use the shim or not. Should I wait until everything is in place, get it aligned, and see if the camber shim is needed?
For anyone that had this situation, what steps did you take?
