I need to replace inner and outer seals on my Dana 30, Bronco is leaking on the front left side. I've seen a lot of info on removing everything up to the axels, however the only info I can find on dropping the differential (carrier) is regarding a Jeep https://youtu.be/5DijgyyqZb0, from this video the differential just drops out. Any tips on dropping the 66 Bronco front differential is much appreciated.
The 1966 Bronco shop manual mentions shims and preload but is this really an issue on the front differential ? It is a street only Bronco that will never use the fwd, I just want to stop the gear oil leaking.
Tony
Tony
