Ready for body work and paint, question
Stu7054
Getting ready to send my body to a painter for final body work and paint.
I bought someone's unfinished project so a lot of the panels have been replaced (quarters, rockers, door pillars etc.) History unknown.
The plan was to put the body on the frame for him to make sure everything is aligned before paint then take the body off to keep overspray off chassis. The plan is to eliminate sending the completed chassis to the paint shop.
Question: I have a bare chassis/roller. Would I have problems if I aligned the panels and painted the body on the other roller then transfer it to the completed chassis?
I'm worried about how things will line up.
suckerpunched
IMO you should do final alignment on the frame you are using along with new body mount bushings. could save yourself a lot of grief down the road.
bamabaja
The Shoals
Sorry for semi thread drift but is there an correct or preferred order of sheet metal parts assembly on chassis? I have asked several vendors and web search with no results. Floor, tunnel, cowl, pillars, doors, front inner fenders, etc ? Thanks.
Stu7054
Stu7054
I'll be using all new body mount bushings as just about everything Is new or rebuilt.
That was another thought-line it up then transfer it to the rolling frame.
KBUCK1
Chances are it will be different from one frame to the next. I built mine on one frame and then moved it over to the other. Things changed. Had to add shims on some body mounts and shave some from others
sanndmann3
Definitely the way to go...
there will be differences in how things line up from 1 frame to the next.
Stu7054
Stu7054
That's what I was afraid of. Looks like I'll be playing musical chassis..
rydog1130
sent you a pm
