So, body is finally painted. I have questions.
Rolling chassis has running engine, gas tank, fuel line, brake lines, trans, exhaust, drive shafts all in place. Per advice from someone on this site I actually removed the gas tank sending unit and verified my Sherman Tank was good, fuel pickup was in place and I tested the sending unit with my gauge assembly. All that checked good. What else should I install or do before setting the body on the frame? I guess the wiring harness goes on after the body is on. At this point, is there any gotchas if I set the body on? Like, will I be kicking myself because I didn't install something now?
Thanks.
Thanks.
