I've had the hard top off the Bronco for at least 9 years. Recently I pulled it down to re-install it and having what might be an issue with it. Do hardtops always sit flat and square on the bed rails & windshield frame after being removed for a long time?
I ask because the top is not sitting square and flat against the windshield frame. I can pull it down into place by hand and I'd imagine bolting it in place would do the same, but then it would be under tension. Is that normal for a hardtop that has been off for a long time?
I'm not trying to permanently install it right now....just trying to get it set in place to take some measurements for new cage building & fitting.
