- Oct 25, 2016
- 941
BC Bronco SS Remote Hood Latch
As mentioned, the AC condenser placement required either major cutting of the radiator core, or getting rid of the factory hood latch. I opted to get rid of the factory hood latch. I read positive feedback on the BC Broncos hood latch and gave them a call. As it turns out they were just developing a stainless steel version and I think I may have got the first one. They also have developed a release handle that matches the factory knobs. I had a hard time finding pictures of the remote latch so I have posted some here.
This is a little tricky to install. I had to remove the inner cable from the housing in order to install it through the dash. Then it was a real pain to “rethread”. The grill needed to come off to install and I needed to cut out the piece of sheet metal that retains the factory nuts that are used for the factory latch. The grill needed to be reinstalled loosely in order to feed the cable into the latch and secure it. Very close quarters with the condenser and safety catch but everything fits - barely. It took a bit of adjustment to line everything up but it works great. As you can see, I tried to keep with the factory look by installing the release above the choke and throttle cables.
Overall this is a real nice piece that I would recommend. BC Broncos was great to work with and figured out a solution for me when I explained I wanted to install it in the dash. They normally provide an underdash bracket and also thought that I may be the first one installing into the dash.
Next up is to troubleshoot some light and blinker issues and move on to getting the rest of the AC installed.
