MidwestTexan
- Apr 1, 2018
- 92
I purchased a 90' 351W that was in a F350. I was able to drive it prior to him pulling it which it drove well. It has factory EFI, which I don't think I'll be able to use. I have a 600 cfm carb that I'll use until I decide if I want to go EFI or not. Would the below parts get me to around 400HP and 400TQ?
If not, or if there is a more cost effective way I'm all ears. The total cost plus gaskets, bolts, timing chain, etc is around $2,500. Thanks and have a Merry Christmas!
Lunati Voodoo Cam
https://www.summitracing.com/parts/lun-10350701
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,000-5,500
Intake Duration at 050 inch Lift: 213
Exhaust Duration at 050 inch Lift: 219
Duration at 050 inch Lift: 213 int./219 exh.
Advertised Intake Duration: 256
Advertised Exhaust Duration: 262
Advertised Duration: 256 int./262 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.483 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.499 in.
Trick Flow® Roller Rocker Arms
https://www.summitracing.com/parts/tfs-51400510
Edelbrock E-Street Cylinder Heads 5025
https://www.summitracing.com/parts/edl-5025
Edelbrock Performer RPM Air-Gap Intake Manifolds 7581
https://www.summitracing.com/parts/edl-7581
Lunati Voodoo Cam
